2015 ZX10R Rear Shock.
Swansea
Any idea if this shock will fit the 09? If not, what year/s should I be looking for? Thanks in advance, Paul.
Whatever shock you decide on make sure it s close to the standard one . eye to eye length 330mm (13") and 60mm travel (2.63 "). Upper mounting bolt hole Dia 10mm and lower mount bolt hole Dia 12mm.
ZX6RR 04-06 or ZX10R 08-10 model. the 6 model is plug'n play, the 10 model must drill down hole to 12mm to fit or duy a suzuki part to fit with out drilling.
Also the 10 model is 338mm eye to eye so, this is a small problem...
Also the 10 model is 338mm eye to eye so, this is a small problem...[/Q
Thanks for the reply
