LewFZ1
Okay folks so which way do you adjust your drive chain. I suspect there is no difference , the owners manual says adjust on the side stand, the service manual says adjust on a Paddock stand.
Both methods give the same settings 5mm>15mm. must admit 5mm seems tight to me even 15mm seems tight.
What do you set yours to. Torque set for axle nut 150Nm lock nut 16Nm.
