Akrapovic spring length
2pumps
Hi, anyone know what the spring length is on the Titanium Akro that holds the downpipes and the silencer together ? Somehow lost both on mine so would like to replace, also do you really need the Cat that slips between the 2 pieces of the exhaust ?
Just found this on motorsport.com:
The PS1 springs measure 80mm and the PS2 measure 60mm.
Dirt Bike & Motocross Online Store | MotoSport
so there would be no issues running without the cat or the DB killer, would the diag still be set at 18 ?
Hi TT, at the moment it's set as standard 0,0,0. I was under the impression it had to be set differently for the Akro ? is this not the case??
Most are setting them to 14...
If you have our ecu flash and custom map loaded you can set it back to 0 across the board and it will be fine.
