cheap and cheerful aftermarket CNC chain adjusters?
Yepp I have a set, seem fine to me and very easy to get an accurate wheel adjustment, better then the stock adjusters anyhow, and the look pretty as well especially in blue.
Just remember no matter how accurate the markings on these adjusters are, the inaccuracies present in the '09 swinging arm means it's extremely unlikely you'll end up with matched numbers on the adjusters when your wheels aligned.
When i get this tensioner i'll check it with the laser aligner.If it's wildly inaccurate i'll go back effing with the laser.
Good thing is i've got a Scottoiler so no need to adjust the chain that often.
PS: i received/installed and tensioned the chain to 22mm and then tested it with the laser aligner....it was SPOT ON. :)
