Clutch lever friction point adjust.
Greece
Hello all,
As the title says, i would be interested to know if anyone can share information regarding the clutch lever friction point adjustment (spent some time searching the forums for such info but with no avail).
As a rider used to a long term relation with Italian style (Ducati and Aprilia owner for 7 years) i found MT-07's clutch lever to be very short in terms of engagement.
I would like to know if there is a way to adjust the retail lever or I have to go for an aftermarket one.
I will appreciate any answers :)
Cheers.
Hello friend,
Since I haven't received my MT-07 Manual, didn't had any reference to check.
Also i was used to hydraulic clutches.
Never the less, a friend from here send me a link for e-manual.
thank you for your answer tho :)
No problem.
I thought that might be the case that you were used to hydraulic clutches.
It the same principle as adjusting the brakes on a bicycle, just twist the little screw thing on the handle wire, in for slacker wire ( bite point further out) and out to tension wire ( bite point further in).
Just remember not to have the slot in the adjuster screw face up as water will then get in and your wire will rust, have it face down.
