Hi, The reasonable advice would be appreciated, please. Has anybody have done DIY ECU tuning, what software and interface (harness) can be used ? I have got an intention to reduce radiator fan temperature and disable injector decel cut for my
MT-07. Thanks.
Gratefully,
hi Jerome
I did this in 2018 with FTecu
firstly if you use FTecu only download and write your ECU with the exact matching ecu part number ie (1WS-8591A-10 this may not be your number) that is LISTED, and before you rewrite the ecu read (copy) and save to file that way you can rewrite anytime back to standard should you make an error and you can start again.
secondly there are several how to do on YouTube just google FTecu
I was led astray and went with the closest number and things did not go all that well, I then purchased the Active Tune and has now corrected the rattly engine and tune, FTecu read my latest ecu read and confirmed all is good
To get the lower the engine temps to register which you can manually adjust set at 85-90c or 185-194f smaller adjustment do not register or at least when I did mine.
Although expensive I fitted their Quickshifter
So a summary of mods Bike is 2016 689cc
FTecu bikeside kit
FTecu Active Tune
FTecu Quickshifter
Andreani fork cartridge conversion, with Hoey
suspension, compression valve mod
Nitron R2 rear shock
Shorty folding brake and clutch levers, short screen
home made adapter plates to move footrest back 50mm and up 25mm passenger brackets removed
Bike had 2500Kms on when I bought it and came with Akra Titanium
exhaust, yamaha comfort ? seat since modified
Have done 3 track days early last year and have 1 planned in a couple of weeks
oh and the rider (me) just turned 77
and also have a Vstar 1300 also lots of mods for two up riding.
all the best to everyone
Alan, South Australia
