Hi Boys
I purchased a tail light addon [RED MINI LED SMOKE Brake Tail Stop Light For Yamaha MT-07] from ebay
it was not what I thought it would be, but nevertheless I attempted to fit onto the rear below existing tail light sitting partially on the number plate.
before I did so I checked it worked [from hong kong] via my drill 12v battery, it did function .
so from there I started to wire it into existing rear light cable just before the 3 pin connector, the unit also has 3 wires and they did function as I said via the battery.
however once wired and reconnected the existing light and gave it ignition, the existing light worked fine but the addon was dead as a dodo.
the addon appears to be led as it the tail light and there was continuity on the cables I split via a split connector.
but nothing from the light. as the light is a sealed unit I could not see if there was power to the addon.
any thoughts would be most welcome
cheers
kev
cheers
kev
