TJ63
I had this happen to me yesterday. First time in the best part of 800 miles.
...snapping it open like he seems to do would likely catch the
injection system out and feed the motor with to much air in one gulp...
Had the same thoughts as you watching the vid. My MT has stalled 2-3 times in 1500 km, for some reason or another, nothing to worry about. Revs at idle is maybe on the low side, but you definitely don't need to jerk the throttle at red lights to keep the engine running.
That's correct. I am at the traffic light in 1st gear with the clutch in. And when just about to ride off the engine cuts out![]()
...It's nothing to do with the clutch, or whether it's in gear or not. What is happening is that the moment you open the throttle, there is some kind of fuel supply issue, and under certain very specific circumstances, it causes the engine to die...
yep i have an akro fitted and does it the same as it did with the standard pipe![]()
