I get a sound, it's a bit like pinking but when I roll off throttle or use engine braking not when revving the engine. Pinking usually only occurs under load with lean fuel, not the case here. I'm more certain than not that it's not a timing chain as for me you would expect a rattle when revving the engine from idle (a la Suzuki sv650 rev engine slowly in 1000rpm stages and a bad one will rattle like a bugger) and a timing chain rattle is a bit less "tinny" and more dull as well as come with other tell tale signs such as lumpy idle, powerless, difficult starting etc which you encounter with mis-timed engines.
I would have thought it highly unlikely a new mass production engine will have valve clearance issues, which is best described as a distinct almost hollow tapping at idle which increases frequency with revs.
My drive chain has stretched a bit with running in semi-hard (giving everything a good stretch, clutch and throttle cables too) so with first service next Saturday it will be interesting to see if it goes away or reduces a lot. My money is that it will.
