Scottoiler
Hi all
Anyone fitted either the V or E system to an MT-09 / Tracer yet ?, if so where as the reservoir been fitted on your particular model
I fitted a V-system to mine. The reservoir is kinda wedged in the small rectangular area under the seat bracket; I dremeled out a small semi circle of plastic (there goes the warranty...) on the rear "wall" of the area to allow the reservoir easier access in and out. Although the angle is a very long way from vertical, it does its thing no problem.
Hi Wharfe
That was the way how the reservoir was fitted to my 600 Fazer, under the seat next to the sub frame, Scottoiler don't really give a good description of where they fitted it on the Tracer
unless you buy the touring reservoir which goes behind the number plate
Yeah, that's usually where the Scottoiler instructions get a bit vague. But - this is working fine for me too. Coincidentally I also run a Fazer 600, same set up as yours. Great minds...
