You misunderstand or I don't make the point clearly enough, what I am saying is that if I adjusted it to allow me to set theThere's plenty of adjustment at the other end, I'd shorten it there, and wind the handlebar adjuster in. Mine has about 3mm between the lever casting and the round gnurled adjuster thing.
The clutch end has two bolts either side of the bracket, just loosen those and you can set it wherever you like.
adjustment with the bar end adjuster further out it would make the angle the cable sits at more acute and more likely to rub
the free play is fine I just wonder if those that have had problems have the bar end lever adjuster further out.
