Im having trouble with the auxiliary DC point or maybe..??
Is anyone have any issues with this point.? You know the one under the side cover left side of the tank..??
Because so far ive gone through... 1 USB connector & 1 SAT NAV holder.. Im starting think it maybe causing something?
The fuse for that connector is rated 2A. If you take more current from it (A USB adapter and a GSP adapter shouldn't) the fuse will blow up. Nothing bad.
I suggest using some kind of power distribution block, like a fuzeblock, wired directly to battery with a single in-line fuse. I then only use the auxiliary as the switched source on the fuzeblock. Makes it easier to hook things up in the future!
Well at the moment im trying a different way..
After Checking the wiring diagram ive settled with this
I've used the aux dc connector but only the positive as this is what i'm after so when i switch off ignition it powers down my devices
The Negative is from the frame not the wired one on the plug...
So Far So Good....
